Traffic UP/down between Server and client in gl inet routers but no acces to internet browsing
Hello, i have a problem with acces to any site via https/ http, the client vpn and the server are connected I see the traffic up and down, I used WhatsApp application for messaging and calling its works fine, only browsing is not working?
Any solution please ?
The server works fine before, just when I switch off my router and switched in and all is down now for me after reset and created my vpn WireGuard I get the connection problem with the browsing
It looks like the DNS not works.
  1. Does the VPN Client router enable the AGH?
  2. Try to manual config an DNS server on the GL GUI > Network > DNS.
  3. Reduce the WG MTU on GL GUI > VPN Dashboard > WG Client > Options.
Thanks for your return, but my DDNS résolve correctly, I get the ip from my ISP from WireGuard server.
I have the version 4 of mars 2023 with killing switch option in client vpn to keeep this option.
I test now only with my WireGuard application in my laptop and still have the same problem
Where can I found the Network / DNS is not present in the current version please.
It looks like probably the VPN server issue, please contact the VPN support.
DNS is different with DDNS.
It may be a DNS issue since it unable to open HTTP/HTTPS website.
What is the equipment model?
Please upgrade to the latest firmware version.
I have a GL-SFT1200- 921 with 3.216 version.
I can connect to the IP of server router from my laptop via WireGuard application, I see the ip public for the ISP operator and also, thé transfert data Up and down, but always not acces to internet browsing.
For the upgrade I want to keep the kill switch for this version under vpn client.
The killswitch already supported in all firmware version, including the latest version.
Try upgrading the latest beta firmware for the SFT1200:
https://dl.gl-inet.com/router/sft1200/beta
Could you access the browser webpage normally with the laptop WireGuard application?
If not, please check your VPN profile if there is the DNS parameter.
I upgraded my WireGuard server to the last version, I tried now to connect with my WireGuard application from my laptop, always internet access browsing page is down, I see the DNS parametr is set to 64.6.64.6.
Ip interface 10.0.0.2/24
MTU : 1420.
For the peer : 0.0.0.0/0, ::/0
I see the traffic up down from application and my server WireGuard but always without acces to internet browsing
It's not clear from the above. What device are you running the Wireguard server on.
I have a GL-SFT1200- 921 router runing as a server with WireGuard server and I used the WireGuard application in my laptop to connect in the VPN, before all works fine from last year , only when I disconnect the cable I losed all acces to the internet browsing, I’m now connected with the application WireGuard I see the traffic Up Down, I can ping the 8.8.8.8 from application client in my laptop but there no resolution of the IP address.
Nslookup of the ip or link not work at all.
I get my public IP from the main router 91.x.x.x : 51820.
I dont understand why I have the traffic without internet browsing ( resolution )
Thanks in advance for your help
Try to directly input a custom DNS server IP on the virtual network card wireguard to see if it works well.
If are the LAN clients connected to the SFT1200 router, internet browser work well?
