My Spitz AX arrived today and I am excited to get it to work.
I have been using a eSim for data on the phone for some months now and the idea was to transfer this eSim to Spitz. I do not have the original physical sim card.
So, is it possible to have Spitz work on the eSim without inserting a physical sim card?
Ok, thank you.
I bought a new sim card with data connection which I can convert to esim. I also bought the physical esim card from GL Inet. Now the question is how do I upload the QR code from my service provider to the router?
Also after upgrading to firmware in the following link http://download.gl-inet.com/firmware/x3000/esim/ for esim support the internet and cellular lights are off. But the internet and cellular connection is working
There seems to be a issue.
When using eSIM and the Internet is normal, that 2 LEDs should light up.
If it uses a normal phone SIM card, will the cellular and Internet LED light up?
If not have normal SIM, connects with Ethernet WAN/repeater, etc., will the Internet LED light up?
Could you please share screenshot of the GL GUI > Internet, and photo of the router LED?
I will send the pic later becquse i am not close to the router.
However the physical esim is not present in the router but the firmware posted in my last post is running. I strongly suspect its a firmware bug.
