I have a GL-AX1800 running on 4.6.8. I have set up PIA VPN with a wireguard configuration. I want to ensure that Transmission running on the router goes through the VPN, but not connected devices. I have set up based on client device and used the MAC of the router to 'Use VPN'. I have confirmed that connected devices are not using the VPN. Will the router use the VPN and how could I confirm this. Or is there a better way to achieve this
Have you installed the plugin Transmission on the router?
And hope that the router itself transmits the Transmission data through VPN?
Yes, Transmission and VPN both up and running. Just need to ensure that Transmission goes through the VPN, but connected devices do not
I am not sure if the VPN can proxy local traffic, wait a minute, let's check it first
Do you have an update on this for me?
R&D is under plan to check if can / how VPN proxy the local traffic. Please wait a while.
Sorry for the late reply, I think we have a solution:
There is a user group "explicat_vpn", and the policy always goes to VPN, you can use this user group to execute the service process, for examle:
sudo -g explict_vpn curl ip.sb
Firmware upgrades to v4.8.1 or above is required.
For the AX1800 it now can install v4.8.2:
