Hi. I’ll start off by saying I don’t understand much about networks in general so thanks in advance for the patience.
I just bought a Slate 7 to use as a travel router in hotels. I want to test it and learn how to use it so as a first step I wanted to connect it to the main router I have at home, a Flint 2, and see if I can get the Slate 7 working.
For context: I’m not using VPN on either of the devices. My Flint 2 has Access Control enabled in allowlist mode. I checked my Slate 7 MAC, put it in the allowlist and confirmed in the Admin Panel of my Flint 2 that the Slate 7 shows up as connected and, as far as I can tell, has access to the internet just like every other client.
I set up my Slate 7 to work in repeater mode and was able to wirelessly connect it to the network being broadcasted by my Flint 2. That’s as far as I got. My Slate 7 is connected to the Flint 2, but it doesn’t have internet access.
When checking the Admin Panel → Network → Internet → Repeater on the GL.iNet app, there’s this legend at the bottom:
LAN subnet is in conflict with the WAN subnet, please Change LAN IP to a different IP address.
Connected to the parent network, but the inerface cannot access the internet.
If I click “Change LAN IP” I go into a section where there is a “Router IP Address” that I can edit but I don’t know if this is safe to do and, even if I did, I don’t understand what should I change it to. Surely I shouldn’t just change random numbers, right?
To make things more weird, every like 5 minutes the Slate 7 will connect to the internet and for a brief second the “LAN subnet is in conflict with the WAN subnet, please…” legend will disappear and immediately come back again. I can also confirm that the Slate 7 very briefly does have internet access on the Admin Panel of my Flint 2 because on the client list I will see that the Slate 7 was a few KB of traffic. Crucially it’s only upload but 0 download.
My questions:
- Would anyone care to explain in the most basic language possible why this is happening?
- Anyone know of a solution?
- Do you think this would also happen if I actually tried to connect to a hotel network?
Many thanks in advance for helping me and have a great day.
