"Travel" Routers getting bigger and bigger
I’m agreeing with elorimer. GL-iNet’s power is the fact their stuff works with OpenWRT. The advanced OpenWRT can do amazing things here. I’m not sure if I would have had any of their devices if they didn’t have that. I honestly believe they are doing their best to find the best balance between size, power and features.
I do also like the GL-iNet own GUI to simplify common network configurations, but also some more advanced network setups. For the not-OpenWRT guru, that part is a massive feature!
I like the discussions when some relatively complicated setup with Adguard, VPNs etc fails to make a captive portal work. I frequently expect most of the time one of those more advanced features is possibly fucking the user over :wink: DNS rebinding might not work, or your captive portal might require bypassing the VPN rules. And you might be best off using the DHCP provided DNS servers instead of something else (like DoH?). I honestly rarely have trouble with captive portals on my travelrouter config, but I also have multiple LAN networks in there. One which is the plain and simple pass-through network without custom DNS/Adguard/VPNs/DoH etc etc, with as sole purpose to just allow me to get to the captive portal. The others have their purposes (VPNs, AdGuard, etc etc).
I rarely see those 8x8 setups. They exists, but those are high density enterprise access points, which I honestly do not see in most households. 4x4 I do see. Client devices with wifi 4 streams actually also pretty rare.
Or do you mean multiple 4x4 radios in the (2.4GHz/)5GHz(/6GHz) band? That’s also doable in the consumer world.
In home networks I probably would go for multiple APs instead of 1 big device. Especially when the house is also filled with smart (but slow) gadgets that suck up massive amounts of air-time.
Pretty much nonexistent. A 4x4 router is only useful with multiple clients.
Of course, I mean 8x8, not dual chain 4x4: you can use the same 4 antennae for those radios. Still not useful on a travel router if you have just a few devices.
That’s the smart thing to do but not a very common one. It also means you can avoid spending big money on 8x8 APs and just use multiple 4x4s.
Thank you for your feedback.
Now that the iPhone finally has USB C thanks to the EU, it should hopefully pave the way for the extinction of all other USB ports!
Come on GL-iNet everything from now on needs to be USB C.
Whether it’s USB C in or USB C out.
No more irreversible USB A ports please :grin:!
And also please bring back small form factors! Don’t mind width and length so much.
But thickness please reduce back down to 2cm or less
TP Link Nano compared to previous smaller GL-Inet vs current large form factor GL-Inet
The TP-link TL-WR802N is pretty much comparable to the GL-AR300M spec wise. The additional size does give more power/features.
Yes I’d happily buy the shadow but only if and when both the Micro USB and USB A ports are changed to USB C
Not really a fair comparison from a feature to feature perspective, though the Slate to Opal does show how much a Dual Band unit has increased in size albeit with higher specs. True comparion is Mango/Shadow v TP-Link. They are both slightly bigger but give additional functionality, primarily for me around OpenWRT and functionality rather than the physical additional ethernet port and USB port.
My ideal for my use cases, a dual band repeater (could even do without ethernet and USB) the size of Mango or Shadow or even better, size of the USB 150. Really high specs not important (sames specs as AR750/S) :slight_smile:
Currently AR750 or AR750s is still my go to overseas travel router for its combination of size, weight, power requirements and specifications.
Oh and worth noting that the AR750 Creta is actually based on the same chipset as the Shadow.
Yes like for like is Shadow or Mango but please @Hedwig add USB C for both power in and tethering!
Hoping all the industry follows now that Apple have finally been forced by the EU.
I am a pilot and always looking to minimize the things I carry when going on a flight and abroad.
Cables and chargers being a big gripe!
You can leave a small and cheap USB-C-to-micro USB adapter plugged into the router:
Come on GL-iNet bring us a new version of Mango and Shadow in same size or smaller with USB C for charging. And a second UBS C for tethering :pray:t4::pray:t4::pray:t4:
I’m looking at other solutions to replace my current GL iNet travel routers, as I really do not want to carry anything bigger than an AR750S, and GL iNet seems to be going in a different direction.
The specification on the new NanoPi R2S Plus from Friendly Elec that is not much bigger than a Shadow, has 1GB RAM, 32GB eMMC, USB C power, and optional m.2 WIFI card, shows it is still possible to build a small, well-equipped router. Its not perfect, but it is much closer to what I need.
I want something that is no thicker than 20mm
The TP Link WR802N is 18mm
The Brume is 22mm
The Slate is 24mm
The Mango is 25mm
The NanoPi R2S is 27.5mm
And we need USB C on everything! Both In and Out!
Come on GL-iNet!!!!
Try make you own router rasbeprry pi🤔
