Yes, I know this was a bad idea, but I was having some major issues related to the wifi repeater / DNS, and was hoping the upgrade would help. Any ideas what I can do other than a firmware reset? Can I find the old versions of those packages somewhere?
Cool, thanks. I did a reset, and resolved my issues, just a little bit annoying :). So far, I’m very impressed with the new firmware, and of course, the 750S is really a nice little box! Going to put it to the tests on my next trip (tomorrow :).
For NordVPN configuration, you can choose some configuration files, then copy those files to a folder and re-zip it. I consider it could upload on UI If it less than 5MB.
