I’m using the new GL-MT3000 on firmware 4.2.0 release1.
The issue is that when connecting to wifi (any 2.4/5GHz, guest or regular) the signal drops immediately after the connection looks like it is established. The router is in repeater mode but all wireless settings are default with max power and I assume using auto channels. I’m certain I have the password correct and everything.
I’m going to post logs below from the system log the router is reporting during the period when I’m attempting to connect from an android phone. Also note I’ve been attempting to connect to this router from multiple devices including another phone and a laptop as well and same results from all of them. This issue is only for wireless. A lan cable is working without issue. I’d appreciate any help. Thanks!
Wed Mar 1 10:18:08 2023 kern.err kernel: [ 188.657609] 7981@C14L1,MulticastFilterTableDeleteEntry() 430: the Group doesn't exist.
Wed Mar 1 10:18:08 2023 kern.err kernel: [ 188.665530] 7981@C14L1,MulticastFilterTableDeleteEntry() 430: the Group doesn't exist.
Wed Mar 1 10:18:08 2023 daemon.info dnsmasq-dhcp[6717]: DHCPDISCOVER(br-lan) 36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 daemon.info dnsmasq-dhcp[6717]: DHCPOFFER(br-lan) 192.168.8.107 36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 188.991386] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 188.997566] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 189.004775] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.011985] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-567) from 36:5b:65:01:1b:db, reason=3
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.251168] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.debug kernel: [ 189.264079] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 189.271136] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.280012] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - 36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.289286] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.298388] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.304417] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.425493] 7981@C15L3,WPABuildPairMsg1() 5278: <=== send Msg1 of 4-way
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.432117] 7981@C15L3,PeerPairMsg2Action() 6197: ===>Receive msg 2
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.438846] 7981@C15L3,WPABuildPairMsg3() 5555: <=== send Msg3 of 4-way
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.445626] 7981@C15L3,PeerPairMsg4Action() 6627: ===>Receive msg 4
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 189.457201] 7981@C15L2,PeerPairMsg4Action() 6989: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 189.540039] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.547137] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Mar 1 10:18:08 2023 kern.warn kernel: [ 189.554207] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:36:5b:65:01:1b:db
Wed Mar 1 10:18:08 2023 kern.notice kernel: [ 189.561460] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-0) from 36:5b:65:01:1b:db, reason=8
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 189.571876] 7981@C08L2,ap_peer_disassoc_action() 3479: ASSOC - 1 receive DIS-ASSOC request
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.580152] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-0) from 36:5b:65:01:1b:db, reason=8
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 189.590514] 7981@C08L2,ap_peer_disassoc_action() 3479: ASSOC - 1 receive DIS-ASSOC request
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.598783] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-3687) from 36:5b:65:01:1b:db, reason=3
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.929487] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]36:5b:65:01:1b:db
Wed Mar 1 10:18:09 2023 kern.debug kernel: [ 189.942394] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 189.949461] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:36:5b:65:01:1b:db
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.958395] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - 36:5b:65:01:1b:db
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.967680] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.976782] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 189.982807] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.105333] 7981@C15L3,WPABuildPairMsg1() 5278: <=== send Msg1 of 4-way
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.111957] 7981@C15L3,PeerPairMsg2Action() 6197: ===>Receive msg 2
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.118683] 7981@C15L3,WPABuildPairMsg3() 5555: <=== send Msg3 of 4-way
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.125310] 7981@C15L3,PeerPairMsg4Action() 6627: ===>Receive msg 4
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 190.136880] 7981@C15L2,PeerPairMsg4Action() 6989: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 36:5b:65:01:1b:db
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 190.154082] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.160270] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Mar 1 10:18:09 2023 kern.warn kernel: [ 190.167424] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:36:5b:65:01:1b:db
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.174621] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-3294) from 36:5b:65:01:1b:db, reason=7
Wed Mar 1 10:18:09 2023 kern.notice kernel: [ 190.185249] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-3295) from 36:5b:65:01:1b:db, reason=3
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 613.932879] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]52:a3:ca:d4:a3:33
Wed Mar 1 10:25:13 2023 kern.debug kernel: [ 613.945804] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Mar 1 10:25:13 2023 kern.warn kernel: [ 613.952868] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:52:a3:ca:d4:a3:33
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 613.961377] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647: Recv Assoc from STA - 52:a3:ca:d4:a3:33
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 613.970731] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 613.979934] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 613.985997] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 614.110676] 7981@C15L3,WPABuildPairMsg1() 5278: <=== send Msg1 of 4-way
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 614.117422] 7981@C15L3,PeerPairMsg2Action() 6197: ===>Receive msg 2
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 614.124326] 7981@C15L3,WPABuildPairMsg3() 5555: <=== send Msg3 of 4-way
Wed Mar 1 10:25:13 2023 kern.notice kernel: [ 614.131050] 7981@C15L3,PeerPairMsg4Action() 6627: ===>Receive msg 4
Wed Mar 1 10:25:13 2023 kern.warn kernel: [ 614.143115] 7981@C15L2,PeerPairMsg4Action() 6989: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 52:a3:ca:d4:a3:33
Wed Mar 1 10:26:19 2023 kern.warn kernel: [ 680.088754] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed Mar 1 10:26:19 2023 kern.notice kernel: [ 680.094943] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Mar 1 10:26:19 2023 kern.warn kernel: [ 680.102149] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:42:b4:f0:f0:84:f6
