Hello all! I’m a new purchaser of this mini router and am following the steps featured on this guide to enable EasyTether.
I’ve gotten as far as step 3.iii and successfully updated the module, and I’m quite sure I’m on the most up to date firmware for my router (3.024).
However when attempting to install the uploaded .ipk file I chose (D:\Downloads\easytether-usb-openssl_0.8.9-5_openwrt-19.07.3\19.07.3\ar71xx\generic\easytether-usb-openssl_0.8.9-5_mips_24kc.ipk) I receive this error.
I’m at a loss on how to proceed as I’m admittedly out of my depth here and following the digestible instructions on the guide. It feels worse since I’m on the last step or two. Would anyone have any insight on what I might do to fix the situation, or what I might be doing wrong?
Thanks for responding! I started using the update command before any attempt at installation just to be sure I was on the same page, but was facing a similar error. Would you have any advice on how to respond to this result?
Thanks a lot for pointing that out! I see that the OpenWrt openssl it recommends appears to be newer than the one I linked. That said there appears to be yet another openssl that’s newer than the Doc you shared. I take it that the best practice would be to use the OpenWrt 19.07.3+, as opposed to the OpenWrt 18.06.2+ they reccommend?
I’ve attempted using both the older one (the openssl from the Doc I shared) as well as what I believe to be the newest one. The middle one (in the Doc you shared) I haven’t downloaded or fiddled with yet.
I regret to say that I have (possibly) bad news. I downloaded the firmware you shared and used the local upgrade option on the router’s IP address and after it uploaded to 100%, said something about WiFi and is apparently inaccessible now.
When attempting to access its functions the same I way I did previously (by following the instructions that came with the box) it doesn’t connect. It’s a little frustrating and feels as though I took a step backwards, but maybe this is the first step to progress. I admittedly feel more lost now than ever since I’m not sure to how to even access the router’s functions.
Additionally, as I write this reply I have apparently had my post and my comments flagged as Spam which is upsetting. Is there some kind of etiquette or rule that I didn’t follow that I should be aware of? If so then that’s my mistake but I can’t think of anything and it’s pretty bothersome.
EDIT: I have since rebooted the firmware and it’s on version 3.024 again. I am uncertain if I misunderstood and did something I shouldn’t have. Was I supposed to use that firmware you shared and perform a local upgrade on the router? It acted a bit odd and I’ve reverted that change.
The forum’s software mark some post as spam and I have no idea of the criteria. But each post will be checked manually and will be restore if not spam.
The new user Randomdude02 tried to create multiple posts with links to imgur.com, but those posts were blocked to avoid spam. The user is still able to create new posts that do not link to imgur.com.
This can be modified via the newuser_spam_host_threshold and allowed_spam_host_domains site settings. Consider adding imgur.com to the allowlist if they should be exempt.
If you want to post images, drag them directly to the post input box and it will upload directly on the forum and place the image in the post.
About the firmware, yes, you just had to do a local upgrade. Strange that the firmware did not actually upgrade, might be a bug. Can you try again?
