Turn off LED help – Vanilla OPENWRT installed on Beryl MT13000
I have a spare Beryl v1, so I thought I’d have a play and installed vanilla OPENWRT, version:
“OpenWrt 23.05.3 r23809-234f1a2efa / LuCI openwrt-23.05 branch git-24.264.56413-c7a3562”
Kernel Version: 5.15.150
As far as I can tell, everything is working very well. I have 3 x SSID, one without VPN, the other two routing through a Proton VPN wireguard tunnel using policy-based-routing. I also have a pihole blocking ads, network wide.
What I cannot figure out now, is how to turn off the LEDs on the router.
When I was using the stock Gl.Inet firmware, I must have turned down the brightness because now, it’s super bright and my wife is complaining.
I have gone to:
Luci / system / LED Configuration – and turned everything to ‘always off (kernel:none)
But the light is still super bright.
Any help would be much appreciated.
Install package: i2c-tools
Enter command in console: i2cset -f -y 0 0x30 0x04 0x00
Add this line to /etc/rc.local to make this permanent after each reboot.
@h8red
Thank you so much, worked first time!
I have a follow up question. As the internal storage is very small, I have just expanded the internal storage using Extroot with a USB drive.
extroot_configuration
But now, using the command: i2cset -f -y 0 0x30 0x04 0x00
no longer appears to work.
the latest version of the i2c-tools is installed Package i2c-tools (4.3-3) installed in root is up to date.
Now I'm using Extroot to extend the storage over USB, do I need to do something different for the command to work?
Thanks in advance for any help.
root@OpenWrt:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 4.3M 4.3M 0 100% /rom
tmpfs 122.2M 124.0K 122.1M 0% /tmp
/dev/sda1 924.6M 19.7M 841.0M 2% /overlay
overlayfs:/overlay 924.6M 19.7M 841.0M 2% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock6 24.9M 15.4M 9.4M 62% /rwm
