Handshake is now acting as my DNS and resolving handshake TLDs for the pad, good Times indeed
Do you mean https://handshake.org/
Can you share your settings so that others may find it helpful.
yes, sure
I wanted to run the node so I needed a higher version of nodeJS that is currently on the
device (ver 8), the node calls for ver 10 or greater, so after giving up on the updating route I
try ubuntu , but I did not like it, with a similar idea I install ArchLinux using a usb (ESPRESSObin | Arch Linux ARM)following step by step instructions and getting access to the serial connection( yes I had to open the little guy) connected my cables and interrupting the booting process type the common commands in the instructions and finish booting from the usb. ufff tire of typing get back with how I install the HSD node, if you can make it this far the rest is interesting
ok the second phase, once I new everything was running correctly like it should , with no intervention, the default settings got me cover, very nice. I started with setting the time
timedatectl
pacman -Syu update
pacman -Syu nodejs npm
pacman -Syu unbound
pacman -Syu git
pacman -Syu make
pacman -Syu gcc
npm install loady
git clone git://github.com/handshake-org/hsd.git
cd hsd (change directory to hsd)
npm install --production
once you are done with all this the you are done , you can test it for now by
./bin/hsd
ok too much typing , the last phase will let me run the node automatic so it just runs , if is not running I will not get my DNS , break
oh I forgot the link that I used (ESPRESSObin Wiki | Boot from removable storage - ArchLinux) was the one I used , I had no
success with that storage , so I used a usb and this link was useful
the final phase, I noticed that dnsmasq and system resolve was listening to ports I needed to
use
netstat -tulpn
so before I nix both of this services I install a basic dhcp server
pacman -Syu dhcpd
pacman -Syu cronie ( more on this later…reference cron - ArchWiki)
and disable both services by
systemctl disable systemd-resolved
systemctl disable dnsmasq
systemctl mask systemd-resolved (not let it start at boot)
systemctl mask dnsmasq
by doing this the internal resolver gets ax and the dhcp,dns, provided by dnsmasq gets ax
now my dhcp server becomes dhcpd after locating and editing the file
nano /etc/dhcpd.conf with
option domain-name-servers 10.0.0.1;
option subnet-mask 255.255.255.0;
option routers 10.0.0.1;
subnet 10.0.0.0 netmask 255.255.255.0 {
range 10.0.0.150 10.0.0.250;
(yea the whole content of the file gets erase with just whats above )
in order to start this service at boot
cp /usr/lib/systemd/system/dhcpd4.service /etc/systemd/system/[email protected]
Then edit the ExecStart line to include the interface:
#nano /etc/systemd/system/[email protected]
… [Service] … ExecStart=/usr/bin/dhcpd -4 -q -cf /etc/dhcpd.conf -pf /run/dhcpd4/dhcpd.pid %I
(dhcpd - ArchWiki) reference at the bottom of the page
now I had dhcp running again , next was having my node start at boot , I did this by running cron
EDITOR=nano crontab -e
@reboot $HOME/hsd/bin/hsd --ns-port 5300 --rs-host 0.0.0.0 --rs-port 53
enter then exit
systemctl enable cronie.service
check your hard work by
