Hi team.
Could you please confirm how to turn wed off on 4.6.2 mtk for MT6000.
Thank you
Hi team.
Thank you
Use this in the CLI to check if its active:
cat /sys/class/ieee80211/phy*/device/driver/module/parameters/wed_enable
If it errors there is no file it probably is disabled, Y means enabled, it does it for both 2.4ghz and 5ghz.
And in /etc/modules.conf
You put:
# examples:
# options mod1 option=val
# blacklist mod2
options mt7915e wed_enable=N
The default value should be N.
Thanks for suggestion. Im aware of this solution, but not sure this works on closed mtk. As there is no modules.conf file..
i also dont have modules.conf
Only way to verify is with:
That is taken from the runtime directly reported by the linux kernel driver, i dont think that sys call differ between mtk version and normal openwrt, the modules.conf might be, but then you should have a look here as well /etc/modules.d, honestly i never seen this enabled by default on gl-inet images, i could be mistaken.
You can turn off hardware acceleration and WED will be off as well.
The point is, that i would like to keep hwo on but wed off due aql issues, is this posible on mtk build at this moment?
Thank you
