hi, I have a new Brume 2 since yesterday, and today started to put dockerd and dockerman on it. The intention is to run homebridge container on Brume.
I followed the instructions in this post.
However I’m hitting issues when pulling images. Images just don’t pull down and luci hangs, until refreshing.
Inspecting the logs of when docker is installed seems to say that it can’t use /opt/docker location because it’s an overlay on an overlay?
Can you help?
Thanks,
Aidan
Thu May 25 21:54:49 2023 user.notice dockerd-init: Adding interface ‘docker’ to network config
Thu May 25 21:54:49 2023 user.notice dockerd-init: Adding bridge device ‘docker0’ to network config
Thu May 25 21:54:49 2023 user.notice dockerd-init: Adding firewall zone ‘docker’ to firewall config
Thu May 25 21:54:50 2023 user.notice dockerd-init: Drop traffic from eth0 to docker0
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Withdrawing address record for ::1 on lo.
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Interface lo.IPv6 no longer relevant for mDNS.
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Withdrawing address record for fe80::9683:c4ff:fe2a:7d71 on eth0.
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe2a:7d71.
Thu May 25 21:54:50 2023 daemon.info avahi-daemon[3747]: Interface eth0.IPv6 no longer relevant for mDNS.
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50Z” level=warning msg=“containerd config version 1 has been deprecated and will be removed in containerd v2.0, please switch to version 2, see containerd/PLUGINS.md at main · containerd/containerd · GitHub”
Thu May 25 21:54:50 2023 daemon.err modprobe: failed to find a module named aufs
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.685096013Z” level=warning msg=“failed to load plugin io.containerd.snapshotter.v1.devmapper” error=“devmapper not configured”
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.687414470Z” level=warning msg=“could not use snapshotter devmapper in metadata plugin” error=“devmapper not configured”
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.726940950Z” level=error msg=“failed to initialize a tracing processor "otlp"” error=“no OpenTelemetry endpoint: skip plugin”
Thu May 25 21:54:50 2023 kern.err kernel: [ 240.303322] overlayfs: filesystem on ‘/opt/docker/check-overlayfs-support681172104/upper’ not supported as upperdir
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.856606976Z” level=error msg=“failed to mount overlay: invalid argument” storage-driver=overlay2
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.857025506Z” level=error msg=“exec: "fuse-overlayfs": executable file not found in $PATH” storage-driver=fuse-overlayfs
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.911413730Z” level=error msg=“AUFS was not found in /proc/filesystems” storage-driver=aufs
Thu May 25 21:54:50 2023 kern.err kernel: [ 240.399548] overlayfs: filesystem on ‘/opt/docker/check-overlayfs-support4185259823/upper’ not supported as upperdir
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.931471864Z” level=error msg=“failed to mount overlay: invalid argument” storage-driver=overlay
Thu May 25 21:54:50 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:50.931575651Z” level=error msg=“Failed to built-in GetDriver graph devicemapper /opt/docker”
Thu May 25 21:54:51 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:54:51.400439031Z” level=warning msg=“Could not load necessary modules for IPSEC rules: protocol not supported”
Thu May 25 21:54:51 2023 daemon.info modprobe: nf_conntrack is already loaded
Thu May 25 21:54:51 2023 daemon.info modprobe: nf_conntrack_netlink is already loaded
Thu May 25 21:54:51 2023 daemon.info avahi-daemon[3747]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
Thu May 25 21:54:51 2023 daemon.info avahi-daemon[3747]: New relevant interface docker0.IPv4 for mDNS.
Thu May 25 21:54:51 2023 daemon.info avahi-daemon[3747]: Registering new address record for 172.17.0.1 on docker0.IPv4.
Thu May 25 21:54:52 2023 daemon.info avahi-daemon[3747]: Interface docker0.IPv4 no longer relevant for mDNS.
Thu May 25 21:54:52 2023 daemon.info avahi-daemon[3747]: Leaving mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
Thu May 25 21:54:52 2023 daemon.info avahi-daemon[3747]: Withdrawing address record for 172.17.0.1 on docker0.
Thu May 25 21:58:06 2023 authpriv.info dropbear[25765]: Child connection from 192.168.0.210:62676
Thu May 25 21:58:09 2023 authpriv.notice dropbear[25765]: Password auth succeeded for ‘root’ from 192.168.0.210:62676
Thu May 25 21:58:31 2023 daemon.err dockerd[17795]: time=“2023-05-25T11:58:31.087179337Z” level=error msg=“Not continuing with pull after error: context canceled”
