If it helps, I just got U.S. Mobile Dark Star (AT&T) to work on a Spitz AX GL-X3000NR that I recently purchased. I had to consult with U.S. Mobile support get my SIM to register and connectivity established. The setup was easy but I had to get the APN from U.S. Mobile support, which is APN -> ereseller. The APN is case sensitive so use all lowercase. I entered the APN, rebooted the router, and Voila! Four bars of AT&T 5G+!!!
So far so good. ![]()
