Uboot luci root password XE3000
I did a forced openwrt sysupgrade using a wrong filename which resulted in box to become inaccessible. Following debrick tutorial Debrick via Uboot - GL.iNet Router Docs 3 I can surf to 192.68.1.1 but I do not get the typical FIRMWARE UPGRADE page. Instead I get LUCI root login. I tried password 'goodlife' and empty password and my own previously set password but cannot get in. Note that tutorial says LAN LED should flash 5 times but it is the Internet LED that flashes 5 times.
Any suggestion to chose correct root password or to improve debrick scenario (holding reset, see LED flash 5 times when power on until WIFI (2.4) LED stays on)?
UPDATE
Eventually (not sure how) I reached Uboot and could flash
