uFi 5G usb
Is the uFi 5G USB project still current? The technical specifications have disappeared from the GL Inet website.
Thank you for your interest. The uFi 5G project has been suspend for some reasons. You are welcome to follow our other product projects. Thanks
I’m currently using the uFi 4G USB, and it’s brilliant. Is there any plan to introduce a VPN client in the software? There were promises to that effect on the forum, and the uFi 5G’s specifications suggested this would be included.
Sorry, there is no plan to add vpn at the moment.
