I strongly disagree. Nginx should be removed. It's bloat. There's no need for a multi-process, web server capable of c10k requiring over 15x the flash space and 37.4x the RAM when OWRT is a single seat administered, embedded system.
-rwxr-xr-x 1 root root 673.6K Oct 17 2024 /usr/sbin/nginx*
-rwxr-xr-x 1 root root 44.4K Oct 17 2024 /usr/sbin/uhttpd*
ps -w | grep nginx | grep -v 'grep' && ps -w | grep uhttpd | grep -v 'grep'
4373 root 7008 S nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf -g daemon off;
4523 root 11188 S nginx: worker process
4524 root 10704 S nginx: worker process
4525 root 10288 S nginx: worker process
4526 root 10896 S nginx: worker process
3905 root 1560 S /usr/sbin/uhttpd -f -h /www -r router -x /cgi-bin -u /ubus -t 60 -T 30 -k 20 -A 1 -n 3 -N 100 -R -p 12
(firmware 4.6.8-release1)
There's no benefit to Nginx when it doesn't even have proper WebDAV support.
Yes, uhttpd is more lightweight.
GL GUI uses nginx I guess the reason is the early firmware development, nginx was chosen to be able to handle our own API.
If future everything is right, we may consider swapping a lighter http server.
I can't imagine the amount of developer time/'technical debt' that's required for a custom API just to run on OWRT. I've only briefly looked at some of the GL scripts but I can't imagine why write completely custom scripts when uci itself is so easily scriptable.
I could see a custom daemon tunneled thru HTTPS as a endpoint for the GL.iNet app, though... or just push/pull over dropbear:
... but it sure would be nice to get back that RAM from Nginx given LuCI runs Lua to interface with uci.
