UK EE No internet connectivity X3000NR
Hi, I recently bought a GL-X3000NR 5G router and having inserted a EE data sim I am able to see the SIM card on the web interface, can see signal quality graphs but there is no internet connectivity. The sim signal and Internet status lights remain off.
I have successfully received the welcome text messages from EE so the SIM card is working.
Please help
I have just activated a SMARTY data only SIM card. Inserted the SIM card into slot 2, switched the active sim and the web interface correctly shows SMARTY network is connected; good signal quality and I have received a couple text messages confirming the SIM card is active.
However, I have the same result as with the EE SIM card; the internet and mobile signal status lights remain off and there is no internet connectivity.
Considering the cost of this device; it’s a joke of a router. Looks like they spent more money on YouTube influencers to push this product than actually testing that it works in the first place.
Looks like it’s going back to Amazon.
can you send a screenshot of your cellular line in the dashboard? this can help us to help you!
I would update the Firmware and reset the device. It would appear that IPV6 being enabled causes this and detects the SIM card properly for me now.
You might want to update/manually enter EE's APN settings for it to connect. I have had similar issues with EE before with Huawei and TP-Link LTE routers and so I don't believe it is a problem with the router as such.
