I just set up the gl-sft1200 router, I am able to connect to websites when using it in repeater mode, however I get a self-signed security error on every website. There is way to accept the certificate and continue, I am simply blocked from every website. I tried firefox, chrome, and safari.
Did I miss a setup step? I searched for this issue and no one else seems to be having the same issue.
I have the same issue after rebooting the router. It wont connect to anything unless I first log into the admin portal, (I dont do anything in the portal, just log in), then it will connect to websites but I get this security error
After spending hours trying to get it to work, it prompted the captive portal login, I signed in and the internet worked normally. But then 20 mins later the wifi was gone. I rebooted the router and then I was able to connect to the wifi again, but then stuck in the security loop again.
+1 for this. Ensure system date / time is correctly set on your device as this can cause SSL errors. Ensure both the router and the devices are correct.
Also, try using another device to rule out the device being the problem.
