Hi.
I connect through a VPN. Some (one or two) websites do not open (time out), I then switched to a different provider/server and had no problems.
So, my question is why are some sites unreachable using certain providers/servers and is there a tweak in settings (luci) than can fix this?
Alot of websites has dynamic DOS prevention when it see there are too many requests coming from the same IP. Did you notice sometimes on google search, you have to proof you are not a robot?
There are sites that actively block tor and vpn exit nodes.
You can try using the windows/mac/linux client of your vpn provider and see if the site works.
OK, so I tried connecting via the Windows App and that blocks too,
So only way of opening the website in question is to go direct (no thanks!) or use another VPN provider.
I think the top VPN providers have trial periods so you can test your favorite sites.
If not, you can download tor browser and use that for the specific sites that don’t work in the VPN
