Unable to configure MT300N-V2 with usb wifi adapter + repeater mode
Hello community, I have a MT300N-v2. I’d like to add a USB wifi dongle to the router for the repeater feature. I’m running openwrt-mt300n-v2-3.026-0729 firmware.
First question is will this increase my throughput speed when connected to the repeater?
I’ve tried to configure 2 different dongles (Asus ralink 28xx based and a generic mediatek mt7601 based)
The router’s logs appear to see the devices, but when I try to add an interface I dont see a new one, or I dont know what it’s called to add a custom interface. Really, I dont know what I’m doing here.
The one thing I do notice, is that after I add the software package, scanning networks no longer displays any results (or the box that the networks would be listed in) but the connection still works if I previously associated a wireless network to the repeater.
Does anyone have any advice or a step by step guide to help me out?
Can you share your configuration?
Here’s my network config:
cat /etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fd8c:a346:5cdb::/48'
config interface 'lan'
        option type 'bridge'
        option ifname 'eth0.1'
        option ip6assign '60'
        option hostname 'GL-MT300N-V2-1e2'
        option ipaddr '192.168.8.1'
config interface 'wan'
        option ifname 'eth0.2'
        option proto 'dhcp'
        option metric '10'
config device 'wan_dev'
        option name 'eth0.2'
        option macaddr 'e4:95:6e:49:61:e2'
config interface 'wan6'
        option proto 'dhcpv6'
config switch
        option name 'switch0'
        option reset '1'
        option enable_vlan '1'
config switch_vlan
        option device 'switch0'
        option vlan '1'
        option ports '1 6t'
config switch_vlan
        option vlan '2'
        option ports '0 6t'
config interface 'wwan'
        option proto 'dhcp'
        option metric '20'
config interface 'guest'
        option ifname 'guest'
        option ipaddr '192.168.9.1'
Also here’s whats happening with the repeater menu.
Before adding dongle driver:
After:
There is no configuration for dong.
Our interface does not fit this dong, so it cannot be operated in the interface. You need to configure this dong first and then operate in luci
How do I configure the dongle? I’ve installed the drivers but I don’t see a way to configure.
Can you post the content of /etc/config/wireless?
Pls mark your wifi password.
I haven’t tried it yet. But i think this guy here put together a quick guide of how to achieve that:
I tried yesterday to follow the screenshots. But It’s just too confusing. It’s not really easily understandable what he is explaining. He is mixing travelmate with some settings. Do i need travelmate for it?
If someone can explain it a bit more noob friendly. That would be awesome. Anyone?
