I am unable to use repeater functionality on GL-XE300, everytime i try to connect to the SSID the Wifi on the GL-XE300 drops and it is unable to connect to the SSID. I have a GL-MIFI that has no issues connecting to this SSID in repeater mode.
I’ve attached some logs below, GL-XE300 is running latest firmware version 3.212
Thu Apr 7 08:47:24 2022 user.info : saved ssid ignore: Level-Two 0
Thu Apr 7 08:47:24 2022 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=Level-Two, encryption=psk2, bssid=68:D7:9A:xx:xx:xx, wds=0, device=radio0, identity=, channel=11
Thu Apr 7 08:47:24 2022 user.info : [ 2055] gl-wifi-core>> FirewallConfiged
Thu Apr 7 08:47:27 2022 user.info : [ 2876] gl-wifi-core>> bIsStaEnabled=1
Thu Apr 7 08:47:27 2022 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Apr 7 08:47:27 2022 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED xx:xx:xx:xx:xx:xx
Thu Apr 7 08:47:27 2022 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Apr 7 08:47:27 2022 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Apr 7 08:47:27 2022 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Apr 7 08:47:27 2022 kern.info kernel: [ 442.936038] device wlan0 left promiscuous mode
Thu Apr 7 08:47:27 2022 kern.info kernel: [ 442.940801] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:47:27 2022 daemon.notice netifd: Network device 'wlan0' link is down
Thu Apr 7 08:47:29 2022 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Apr 7 08:47:29 2022 daemon.notice netifd: radio0 (8665): sh: /usr/bin/ovs-vsctl: not found
Thu Apr 7 08:47:29 2022 kern.info kernel: [ 444.294451] br-lan: port 2(wlan0) entered blocking state
Thu Apr 7 08:47:29 2022 kern.info kernel: [ 444.299952] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:47:29 2022 kern.info kernel: [ 444.305841] device wlan0 entered promiscuous mode
Thu Apr 7 08:47:29 2022 daemon.err hostapd: Using interface wlan0 with hwaddr 96:83:c4:xx:xx:xx and ssid "GL-XE300-6b8"
Thu Apr 7 08:47:29 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Apr 7 08:47:29 2022 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Apr 7 08:47:29 2022 daemon.notice wpa_supplicant[8842]: Successfully initialized wpa_supplicant
Thu Apr 7 08:47:30 2022 daemon.notice netifd: Interface 'wwan' is enabled
Thu Apr 7 08:47:31 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:47:31 2022 kern.info kernel: [ 446.166361] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:47:31 2022 kern.info kernel: [ 446.185555] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:47:31 2022 kern.info kernel: [ 446.302254] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:47:31 2022 kern.info kernel: [ 446.422259] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:47:31 2022 kern.info kernel: [ 446.532163] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:47:32 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:47:32 2022 kern.info kernel: [ 447.538508] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:47:32 2022 kern.info kernel: [ 447.557704] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:47:32 2022 kern.info kernel: [ 447.672194] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:47:32 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:32 2022 kern.info kernel: [ 447.783781] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:47:32 2022 kern.info kernel: [ 447.892148] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:47:34 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:47:34 2022 kern.info kernel: [ 449.302508] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:47:34 2022 kern.info kernel: [ 449.321697] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:47:34 2022 kern.info kernel: [ 449.432153] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:47:34 2022 kern.info kernel: [ 449.542156] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:47:34 2022 kern.info kernel: [ 449.662255] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:47:34 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:36 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:47:36 2022 kern.info kernel: [ 451.582010] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:47:36 2022 kern.info kernel: [ 451.601185] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:47:36 2022 kern.info kernel: [ 451.712161] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:47:36 2022 kern.info kernel: [ 451.822171] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:47:36 2022 kern.info kernel: [ 451.932181] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:47:36 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Level-Two" auth_failures=1 duration=10 reason=CONN_FAILED
Thu Apr 7 08:47:38 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:41 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:43 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:44 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:46 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:46 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: CTRL-EVENT-SSID-REENABLED id=0 ssid="Level-Two"
Thu Apr 7 08:47:47 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:47:47 2022 kern.info kernel: [ 462.729066] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:47:47 2022 kern.info kernel: [ 462.748353] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:47:47 2022 kern.info kernel: [ 462.862160] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:47:47 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:47 2022 kern.info kernel: [ 462.972159] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:47:48 2022 kern.info kernel: [ 463.092163] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:47:48 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Level-Two" auth_failures=2 duration=20 reason=CONN_FAILED
Thu Apr 7 08:47:48 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:52 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:58 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:47:59 2022 user.info : [ 1754] gl-wifi-core>> Restart wifi...
Thu Apr 7 08:47:59 2022 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Apr 7 08:47:59 2022 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Apr 7 08:47:59 2022 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Apr 7 08:47:59 2022 daemon.err wpa_supplicant[8847]: Failed to stop hostapd AP interfaces
Thu Apr 7 08:47:59 2022 daemon.notice wpa_supplicant[8847]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Apr 7 08:47:59 2022 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Apr 7 08:47:59 2022 daemon.notice wpa_supplicant[8847]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Apr 7 08:47:59 2022 kern.info kernel: [ 474.573986] device wlan0 left promiscuous mode
Thu Apr 7 08:47:59 2022 kern.info kernel: [ 474.578699] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:47:59 2022 daemon.notice netifd: Interface 'wwan' is disabled
Thu Apr 7 08:48:00 2022 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Apr 7 08:48:01 2022 daemon.notice netifd: radio0 (9419): sh: /usr/bin/ovs-vsctl: not found
Thu Apr 7 08:48:01 2022 kern.info kernel: [ 476.135180] br-lan: port 2(wlan0) entered blocking state
Thu Apr 7 08:48:01 2022 kern.info kernel: [ 476.140681] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:48:01 2022 kern.info kernel: [ 476.146563] device wlan0 entered promiscuous mode
Thu Apr 7 08:48:01 2022 daemon.err hostapd: Using interface wlan0 with hwaddr 96:83:c4:xx:xx:xx and ssid "GL-XE300-6b8"
Thu Apr 7 08:48:01 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Apr 7 08:48:01 2022 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Apr 7 08:48:01 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:01 2022 daemon.notice wpa_supplicant[9617]: Successfully initialized wpa_supplicant
Thu Apr 7 08:48:02 2022 daemon.notice netifd: Interface 'wwan' is enabled
Thu Apr 7 08:48:02 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:48:02 2022 kern.info kernel: [ 477.926866] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:48:02 2022 kern.info kernel: [ 477.946212] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:48:02 2022 kern.info kernel: [ 478.062231] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:48:03 2022 kern.info kernel: [ 478.183658] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:48:03 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:03 2022 kern.info kernel: [ 478.293639] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:48:04 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:48:04 2022 kern.info kernel: [ 479.298732] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:48:04 2022 kern.info kernel: [ 479.318007] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:48:04 2022 kern.info kernel: [ 479.432157] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:48:04 2022 kern.info kernel: [ 479.542147] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:48:04 2022 kern.info kernel: [ 479.652145] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:48:05 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:48:05 2022 kern.info kernel: [ 481.059063] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:48:05 2022 kern.info kernel: [ 481.078248] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:48:06 2022 kern.info kernel: [ 481.192150] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:48:06 2022 kern.info kernel: [ 481.302160] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:48:06 2022 kern.info kernel: [ 481.412171] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:48:08 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:48:08 2022 kern.info kernel: [ 483.318797] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:48:08 2022 kern.info kernel: [ 483.337945] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:48:08 2022 kern.info kernel: [ 483.452151] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:48:08 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:08 2022 kern.info kernel: [ 483.573658] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:48:08 2022 kern.info kernel: [ 483.683632] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:48:08 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Level-Two" auth_failures=1 duration=10 reason=CONN_FAILED
Thu Apr 7 08:48:09 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:10 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:18 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:18 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: CTRL-EVENT-SSID-REENABLED id=0 ssid="Level-Two"
Thu Apr 7 08:48:19 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: SME: Trying to authenticate with 68:d7:9a:xx:xx:xx (SSID='Level-Two' freq=2462 MHz)
Thu Apr 7 08:48:19 2022 kern.info kernel: [ 494.478834] wlan-sta: authenticate with 68:d7:9a:xx:xx:xx
Thu Apr 7 08:48:19 2022 kern.info kernel: [ 494.498104] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 1/3)
Thu Apr 7 08:48:19 2022 kern.info kernel: [ 494.612148] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 2/3)
Thu Apr 7 08:48:19 2022 kern.info kernel: [ 494.722149] wlan-sta: send auth to 68:d7:9a:xx:xx:xx (try 3/3)
Thu Apr 7 08:48:19 2022 kern.info kernel: [ 494.832177] wlan-sta: authentication with 68:d7:9a:xx:xx:xx timed out
Thu Apr 7 08:48:19 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Level-Two" auth_failures=2 duration=20 reason=CONN_FAILED
Thu Apr 7 08:48:21 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:26 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:27 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:29 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:30 2022 user.info : [ 817] gl-sdk>> wifi_join return=-5, channel=-1
Thu Apr 7 08:48:30 2022 user.info : [ 1754] gl-wifi-core>> Restart wifi...
Thu Apr 7 08:48:30 2022 daemon.notice netifd: Interface 'wwan' is disabled
Thu Apr 7 08:48:31 2022 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Apr 7 08:48:31 2022 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Apr 7 08:48:31 2022 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Apr 7 08:48:31 2022 daemon.err wpa_supplicant[9622]: Failed to stop hostapd AP interfaces
Thu Apr 7 08:48:31 2022 daemon.notice wpa_supplicant[9622]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Apr 7 08:48:31 2022 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Apr 7 08:48:31 2022 daemon.notice wpa_supplicant[9622]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Apr 7 08:48:31 2022 kern.info kernel: [ 506.162230] device wlan0 left promiscuous mode
Thu Apr 7 08:48:31 2022 kern.info kernel: [ 506.166936] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:48:32 2022 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Apr 7 08:48:32 2022 daemon.notice netifd: radio0 (10238): sh: /usr/bin/ovs-vsctl: not found
Thu Apr 7 08:48:32 2022 kern.info kernel: [ 507.477141] br-lan: port 2(wlan0) entered blocking state
Thu Apr 7 08:48:32 2022 kern.info kernel: [ 507.482709] br-lan: port 2(wlan0) entered disabled state
Thu Apr 7 08:48:32 2022 kern.info kernel: [ 507.488527] device wlan0 entered promiscuous mode
Thu Apr 7 08:48:32 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Thu Apr 7 08:48:33 2022 daemon.notice hostapd: handle_probe_req: send failed
Thu Apr 7 08:48:33 2022 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=11 sec=7 based on overlapping BSSes
Thu Apr 7 08:48:33 2022 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:xx:xx:xx and ssid "GL-XE300-xxx"
Thu Apr 7 08:48:33 2022 kern.info kernel: [ 508.965821] br-lan: port 2(wlan0) entered blocking state
Thu Apr 7 08:48:33 2022 kern.info kernel: [ 508.971322] br-lan: port 2(wlan0) entered forwarding state
Thu Apr 7 08:48:33 2022 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Thu Apr 7 08:48:33 2022 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Apr 7 08:48:34 2022 daemon.notice netifd: Network device 'wlan0' link is up
Thu Apr 7 08:49:11 2022 daemon.info hostapd: wlan0: STA xx:xx:xx:xx:xx:xx IEEE 802.11: authenticated
Thu Apr 7 08:49:11 2022 daemon.info hostapd: wlan0: STA xx:xx:xx:xx:xx:xx IEEE 802.11: associated (aid 1)
Thu Apr 7 08:49:11 2022 daemon.notice hostapd: wlan0: AP-STA-CONNECTED xx:xx:xx:xx:xx:xx
Thu Apr 7 08:49:11 2022 daemon.info hostapd: wlan0: STA xx:xx:xx:xx:xx:xx RADIUS: starting accounting session 7D769D29556A3534
Thu Apr 7 08:49:11 2022 daemon.info hostapd: wlan0: STA xx:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Thu Apr 7 08:49:11 2022 daemon.info dnsmasq-dhcp[5570]: DHCPREQUEST(br-lan) 192.168.8.171 xx:xx:xx:xx:xx:xx
Thu Apr 7 08:49:11 2022 daemon.info dnsmasq-dhcp[5570]: DHCPACK(br-lan) 192.168.8.171 xx:xx:xx:xx:xx:xx Macbook
Thu Apr 7 08:49:31 2022 user.info : gl_health start->
