Unable to connect Windows 10 Surface Laptop 2 to Creta
Hi guys,
As written in the subject, I’ve tried to connect the laptop to my router but after typing in the password the system checks the network requirements and after few seconds it just says “unable to connect to this network”
My Creta is connected to my home router hub via LAN and is in router mode.
I’ve my devices connected to Creta using both LAN and WiFi and all of them are working fine. The issue is only with the laptop.
Any suggestions?
Best regards,
Joe
Can you change the encryption method of Creta and try again?
Try changing between WPA/WPA2 Mixed and WPA2 only.
