I have to connect 2 VPN service at same time. one to be used as default gateway, and other for only tunnel behind NAT to manage that device from outside.
Openvpn works perfect fine (if only openvpn is connected) , no dis-connections, nothing, but as soon as i start the wireguard vpn ( i already have disabled its gateway feature so that it does not become default gateway), then openvn stops working, keeps saying it cannot connect to remote server.
How to make both work ? at same time
(they do work sometimes randomly though)
It’s a challenge to guess what you’ve got. If you post here, using the preformat button in the editor toolbar </> (masking any sensitive data, but not so much that the routes don’t make sense), you can probably get some good insights from the people here. I would post at least three conditions:
Now when i reboot router, then the routing table becomes like below. and there is no internet connection at all. I have to manually stop openvpn as well as wireguard, to resolve it.
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 0.0.0.0 128.0.0.0 U 0 0 0 wg0
0.0.0.0 192.168.0.1 0.0.0.0 UG 10 0 0 eth0.2
10.9.0.0 0.0.0.0 255.255.255.0 U 0 0 0 wg0
127.0.0.1 192.168.0.1 255.255.255.255 UGH 0 0 0 eth0.2
128.0.0.0 0.0.0.0 128.0.0.0 U 0 0 0 wg0
169.33.231.9 192.168.0.1 255.255.255.255 UGH 0 0 0 eth0.2
192.168.0.0 0.0.0.0 255.255.255.0 U 10 0 0 eth0.2
192.168.8.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
Also, when i do the startvpn init script, i get lot of errors , not sure if it is common or not
root@GL-MT300N-V2:~# /etc/init.d/startvpn restart uci: Entry not found uci: Entry not found
well
RTNETLINK answers: No such process
Clearing IPv4 filter table
Clearing IPv4 nat table
Clearing IPv4 mangle table
Populating IPv4 filter table
Rule ‘Allow-DHCP-Renew’
Rule ‘Allow-Ping’
Rule ‘Allow-IGMP’
Rule ‘Allow-IPSec-ESP’
Rule ‘Allow-ISAKMP’
Forward ‘lan’ → ‘wan’
Zone ‘lan’
Zone ‘wan’
Populating IPv4 nat table
Zone ‘lan’
Zone ‘wan’
Populating IPv4 mangle table
Zone ‘lan’
Zone ‘wan’
Clearing IPv6 filter table
Clearing IPv6 mangle table
Populating IPv6 filter table
Rule ‘Allow-DHCPv6’
Rule ‘Allow-MLD’
Rule ‘Allow-ICMPv6-Input’
Rule ‘Allow-ICMPv6-Forward’
Rule ‘Allow-ISAKMP’
Zone ‘lan’
Zone ‘wan’
Populating IPv6 mangle table
Zone ‘lan’
Zone ‘wan’
Set tcp_ecn to off
Set tcp_syncookies to on
Set tcp_window_scaling to on
Running script ‘/etc/firewall.user’ uci: Entry not found iptables: No chain/target/match by that name. iptables: No chain/target/match by that name.
Running script ‘/usr/bin/glfw.sh’ uci: Entry not found uci: Entry not found
Running script ‘/usr/sbin/glqos.sh’
! Skipping due to path error: No such file or directory
Use one vpn at a time. Also you can setup one vpn on your router and another one on your device. In such way two vpns will works at a time. Here are setup guides : https://aeroshield.me/how-to-setup/
