Unable to unbind MT3000 from GoodCloud
Before I begin let me start by saying I already saw this thread FLINT AX1800 - Can't unbind Goodcloud - #3 by devcircus and all the other ones, for some strange reason I am unable to unbind my router.
I deleted it successfully from goodcloud website however when I try to unbind it it says "Network error", I tried several things including rebooting the router, disable and enable again the GoodCloud by router admin panel and then refresh the admin panel, nothing seems to work.
Logs below:
Sat May 17 19:28:17 2025 daemon.info gl-cloud[10002]: (gl-cloud:1115) lua-eco version: 3.7.0
Sat May 17 19:28:17 2025 daemon.info gl-cloud[10002]: (gl-cloud:442) Ubus services init done.
Sat May 17 19:28:17 2025 daemon.info gl-cloud[10002]: (gl-cloud:751) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Sat May 17 19:28:17 2025 daemon.err gl-cloud[10002]: (gl-cloud:756) fetch server fail: connect "52.22.16.89 443" fail: Connection refused
Sat May 17 19:28:17 2025 daemon.err gl-cloud[10002]: (gl-cloud:1142) reconnect mqtt in 5s...
Sat May 17 19:28:22 2025 daemon.info gl-cloud[10002]: (gl-cloud:751) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Sat May 17 19:28:22 2025 daemon.err gl-cloud[10002]: (gl-cloud:756) fetch server fail: connect "13.219.31.177 443" fail: Connection refused
Sat May 17 19:28:22 2025 daemon.err gl-cloud[10002]: (gl-cloud:1142) reconnect mqtt in 10s...
Sat May 17 19:28:32 2025 daemon.info gl-cloud[10002]: (gl-cloud:751) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Sat May 17 19:28:33 2025 daemon.err gl-cloud[10002]: (gl-cloud:756) fetch server fail: connect "52.22.16.89 443" fail: Connection refused
Sat May 17 19:28:33 2025 daemon.err gl-cloud[10002]: (gl-cloud:1142) reconnect mqtt in 20s...
Sat May 17 19:28:53 2025 daemon.info gl-cloud[10002]: (gl-cloud:751) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Sat May 17 19:28:53 2025 daemon.err gl-cloud[10002]: (gl-cloud:756) fetch server fail: connect "13.219.31.177 443" fail: Connection refused
Sat May 17 19:28:53 2025 daemon.err gl-cloud[10002]: (gl-cloud:1142) reconnect mqtt in 40s...
Sat May 17 19:29:33 2025 daemon.info gl-cloud[10002]: (gl-cloud:751) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Sat May 17 19:29:33 2025 daemon.err gl-cloud[10002]: (gl-cloud:756) fetch server fail: connect "52.22.16.89 443" fail: Connection refused
Sat May 17 19:29:33 2025 daemon.err gl-cloud[10002]: (gl-cloud:1142) reconnect mqtt in 80s...
Probably the server is under maintenance during that period.
Please try to disable and enable again the GoodCloud.
Please try to disable the VPN client, ADG.
Can the router be unbinded now?
Hello Bruce, thanks for your response but I had already did all those steps with no luck.
Luckily after days of scratching my head I found the culprit, I was using Tailscale with an exit node, apparently anytime I choose an exit node the goodcloud servers start timing out, I have no explanation as to why that's happening, and it's also happening on some nodes but not others, however I was able to replicate the issue multiple times when choosing an exit node.
The solution turned out to be unchecking the "use exit node" in Tailscale and that immediately enables me to "unbind" from goodcloud and then rebind again.
Thanks
