I’m about to update the firmware on my GL-MT300N-V2 - apparently it’s recommended that I uncheck the “keep settings” options … just what does this mean though?
Do I lose my custom DHCP address range and PPPoE settings? pretty much all I care about!) or is there a smarter way to save/reload this stuff?
But that is the recommendation … so firmware updates essentially become a reset settings and update? … not quite ideal (but I know what to expect and it’s hardly complicated for my current setup).
Is there an option to save settings and then reload them that is supported?
You can create a bash script that will set all your custom values to the right places.
All the router configuration is stored in the /etc/ folder, in /etc/config mostly.
You can upgrade without saving the settings, then run your bash script via SSH to set all the values and reboot. That is how i do
You can download a “backup” of your config through the GUI (at least under “Advanced” or “LuCI”) or from the command line. It is a tar file that can be expanded and viewed on most desktops.
Within the same major release from the same sources, you should be safe to keep your settings.
If you are, for example, upgrading from GL.iNet v2 to GL.iNet v3, across GL.iNet and OpenWrt, from OpenWrt v17 to v18 or v19, or from ar71xx to ath79, or downgrading in any way, then reconstructing your config is the approach I’d recommended.
