Hello. I wanted to see the improvements in beta2 firmwares but some things cannot be read because they appear in an unreadable format. Not all.
GL.iNet download center>>>ReleaseNote.txt
GL.iNet download center>>ReleaseNote.txt
Thank you
Thank you
It seems the release notes are shared across all models and they are all partially readable because the file contains some text in Chinese (according to Google Translate).
Here is the text in English from Google:
Based on openwrt 19.07.5 (AR150, MIFI, AR300M, USB150, N300, AR750, AR750S, X750, E750, X1200, XE300, MT1300, MT300N-V2, B1300, S1300, AP1300, MV1000)
Based on QSDK11 (B1300, S1300, AP1300)
Security:
1. wolfSSL heap buffer overflow in RsaPad_PSS (CVE-2020-36177)
2. netifd and odhcp6c routing loop on IPv6 point to point links (CVE-2021-22161)
3. dnsmasq multiple vulnerabilities (CVE-2020-25681, CVE-2020-25682, CVE-2020-25683, CVE-2020-25684, CVE-2020-25685, CVE-2020-25686, CVE-2020-25687)
4. Increase the limit of password authentication times
New features:
1. IPV6 support (partial function support)
2. Support WPA3
3. Support offline client deletion
4. Added firmware rollback or third-party firmware upgrade warning
5. Add 2.4G WIFI and LTE working channel interference automatic avoidance
6. Support IGMP (AR150, MIFI, AR300M, USB150, N300, AR750, AR750S, X750, E750, X1200, MT300N-V2, B1300, S1300, AP1300, MV1000)
7. Support DLNA (AR150, MIFI, AR300M, XE300, AR750, AR750S, X750, E750, X1200, MT300N-V2, B1300, S1300, AP1300, MV1000)
Software Upgrade:
1. AdGuardHome upgraded to 0.104.3 (MV1000, S1300, AP1300)
Hardware support:
1. Support SPI nand GD5F1GQ5UEYIG
Optimization:
1. Optimize client statistics function
APP support:
1. support V1.0.5
Cloud support:
1. Rtty SSH access (MIFI, XE300, X300B, AR750S, E750, MT1300, X750, X1200, B1300, S1300, AP1300)
2. Rtty HTTP access (MIFI, XE300, X300B, X750, X1200, AP1300)
3. Ping tool support (XE300, X300B, AR750S, E750, MT1300, X750, X1200, B1300, S1300, AP1300)
4. Traceroute tool support (XE300, X300B, AR750S, E750, MT1300, X750, X1200, B1300, S1300, AP1300)
5. RS485 tool support (X300B)
Language:
1. Supported Russian
1. Added VPN status indicator icon to the navigation page
2. Added quick navigation to Wireguard client commercial configuration
3. Removed the import method with JSON format in Wireguard client
Important bug fix:
1. Fix the problem that the upper speed limit function fails in some models
2. Fix the problem of tor initialization failure on some models
3. Fix the problem that the repeater cannot reconnect after the AP is closed for MT300N-V2
4. Fix the problem that the router cannot access the network when the Allowed IPs of wireguard is set as a non-global proxy
5. Fix the problem that the MT1300 cannot access the Internet due to the abnormal addition of DNS when using StrongVpn
6. Fix other known issues
Thank you
I can’t translate by myself with Google, I don’t know why…
My mistake, I will upload the English version again.
