Update 4.7.0 - DDNS not working when wireguard client activated
Hello!
Since updating to version 4.7.0 on my GL-AX1800 I have the following phenomenon with my configured Dynamic DNS under the according menu:
When my NordVPN wireguard client is enabled I get the following error:
Means like: ping request couldn't find the host. Check the name and try again.
Whe my NordVPN wireguard client is disabled I get:
Means like: timeout on request.
So it at least knows the host but can't reply as ping is disabled.
When I use the IP instead of the hostname everything is OK.
This behaviour changed since the last version.
Any ideas how I can solve this??
Thanks!
A lot has changed since the last version :rofl:
Yet they still publish the broken “update”.
You can join the fun here:
Hi!
Thanks for the link to the other discussion.
Actually I am not missing package but the router simply behaves different since before the update.
Before the update it replied with the IP assigned by my provider (which is good). Now it replies with the IP of VPN (different to first post, but anyway bad).
What do I have to change to make the router again reply with provider ip on glddns.com host??
Thanks!
Did you enable the VPN killswitch or the "GL services use VPN" by chance?
No, is disabled:
I have the same issue, dns is not resolving from the commandline. Pinging any external host from the commandline on the router fails, as does opkg update. When i edit /etc/resolve.conf and add a dns server it all works... untill a reboot. Haven't found a permanent solution yet.
