Update: Corosync QNetd for OpenWrt (2-Node Proxmox VE Quorum)
Quick update on corosync-qdevice-openwrt for anyone running a two-node Proxmox VE cluster and using an OpenWrt router as the tie-breaker vote.
The original release packaged corosync-qnetd 3.0.4 for OpenWrt 23.05 to keep a two-node cluster quorate when one node goes offline without needing a dedicated third host. Since posting, the project has continued to mature in production and is tracked in the repository:
What’s Included & Updated
  • Lean footprint: Standalone qnetd daemon without a full Corosync stack—roughly a ~1.7 MB download and ~12–16 MB RAM footprint.
  • Multi-target builds: Prebuilt packages with SHA256 checksums for common targets (including GL.iNet Flint / Beryl AX, Flint 2 / Filogic, generic ARM64 / Raspberry Pi 4, and x86_64), plus support for building additional targets.
  • Streamlined setup: Includes a helper script to initialize the certificate database, configure the firewall rule, and run pvecm qdevice setup from a Proxmox node.
  • Broad Proxmox compatibility: Tested with Proxmox VE 7, 8, and 9, including compatibility handling for OpenSSL 3 PKCS#12 requirements.
  • Upgrade & persistence guidance: Documentation covering installation, verification, and preserving configuration across firmware upgrades (including newer OpenWrt apk-based releases where applicable).
Production Notes
Running this on a GL.iNet router in active production has held up reliably through node outages—when one node drops, the surviving node retains quorum via the router's vote and keeps workloads running cleanly.
Full installation instructions, release artifacts, checksums, and build notes are in the repository:
Feedback, real-world test reports, and requests for additional router/architecture targets are welcome.
If you want me to tailor this further—such as adding specific release tags, new supported targets, or apk vs. opkg notes—share what changed since your first post and I will fold it in.
