Upgrade from 23.05.4 to 4.6.3-op24 keeping settings and configuration
Is it possible to upgrade from the latest release of vanilla OpenWrt 23.05.4 to GLi.Net Native OpenWrt 24 Firmware 4.6.3-op24 keeping all the settings and configuration? Do I have to install the extra packages I have installed myself or it will be done automatically? Thanks
They are 2 separate things I believe even if they are somehow related. Some packages may or may not work with GL's firmware.
I would recommend to start from scratch.
