I have a GL-AR750S and I upgraded from 3.100 to 3.104. The Firewall/Port Forwards tab no longer shows my port forwarding rules. The rules are still active and I can edit them via Advanced/luCI but the main web maintenance panel does not think I have any port forwarding rules.
Thank you for the information but this does not explain why the upgrade caused the rules to no longer be displayed in the standard administration web UI. How can I get them back into the web UI so that I can use the standard administration to manage port forwarding rules?
Also, I would consider this a bug. All other settings from 3.100 are available in the standard administration, it is only the port forwarding rules which got lost during the upgrade. Lost meaning not displayed but still active and accessible via the luCI interface.
I reluctantly just upgraded from 3.101 to 3.104 and noticed the same bug. Your fix does work, indeed, but this is really something that should be fixed. The absence of active firewall rules in the default GL iNet admin UI could easily create issues for someone who hasn’t found this forum topic. Duplicate entries, conflicting entries, etc… Please update this thread when the issue is fixed. Otherwise the upgrade went quite smoothly, and the new package re-installation feature when you open up the “Plug-ins” page under “Applications” is quite nifty as well. Kudos.
