Upgrade GL-E750 Mudi(v2) with RM520N-GL
Swapped out the M.2 card with a RM520N-GL. Using known good Google Fi Data SIM. Says "SIM Not Registered".
Driver issue? bad board? everything I was reading said it should be a simple swap and go.
Will this sim card be recognized on the E750V2 before replacement?
The E750V2 uses a usb port, and using RM520 does not improve the speed
Try entering the command at+cfun=1 ehen the modem is detected and there will be an inscription that the SIM card is not registered
Is it even possible to simple Swap it with a 5G module and make it work?
It depends on which module you have at the moment. If ep06, then you will need a perkhodnik from mini pci to pci, if em06, then it is fashionable to simply change the module. But I don't have such a device, so I can't say if there will be any increase, if it works on the usb 2.0 bus, then there won't be much difference, it seems to me
I know this was a few months ago. Did you have any luck with upgrading GL-E750 v2 to 5G?
