Hey everyone,
I’m currently running a network with a Flint 1 as my main router and an old TP-Link Archer D9 acting as an access point (AP). I've got all my NAS, Plex, Sonos, nodes, etc. sorted, but I’m thinking about upgrading my setup.
Here’s my plan:
- Replace the Flint 1 with a Flint 2 as the main router.
- Use the current Flint 1 as an AP or bridge, and potentially retire the Archer D9.
Main Goals:
- Enable a WiFi scheduling feature (turning off the AP's WiFi at certain times since it’s right next to me).
- Keep all my network settings without causing issues (ideally with a backup/restore process).
Questions:
Has anyone successfully migrated settings from Flint 1 to Flint 2? Would a backup suffice for keeping settings, or would I run into any compatibility issues between the two?
AP mode concerns: I’ve read this post, and it seems like I might lose control over WiFi scheduling and webUI if I use Flint 1 in AP mode. Is that true? Any workarounds?
Could using a mesh setup with both Flint 1 and Flint 2 solve these issues, or am I better off sticking with the AP mode?
Lastly, I’ve got a long cable from the main router to the AP, which is connected to my PC, NAS, and nodes. Should I consider using a switchboard here instead?
Any advice or suggestions would be appreciated, especially on WiFi scheduling and ensuring a smooth transition from Flint 1 to Flint 2 without causing network headaches!
Thanks in advance!
