I purchased 3 routers. 2 MT300N and 1 Ar750.
Upnp is not working for the AR750.
Both MT300N Upnp feature is working perfectly. Tests are performed on the same network and same setup.
Captures are uploaded.
How can I fix this?
How can I fix this?
I confirm this is a bug in v2.27. forgot to patch upnpc, and it cannot determine status of the parent router.
Can you check if upnp actually worked?
I checked and it is not working. Upnp not working.
Can this be fixed? I will like to purchased 3 ar750 devices, but not sure about this bug.
Please download the zip file. Unzip it.
Then upload upnpc
to the router /usr/bin
You can use scp
in Linux or winscp
in Windows to do this. Please check SSH to the router - GL.iNet Docs
The following file is patched upnpc for AR150, AR300M, GL-MiFi, AR750 firmware V2.27 only.
upnpc_lede_ar71xx.zip (8.2 KB)
thanks, I will do it.
Procedure done, issue resolved
