UPnP
Where do I find setting to enable UPnP on the Beryl AX3000?
UPnP requires to install the third-party plugins to support.
Can find it in the plugins feed.
Do you mena upnp server or upnp client?
Generally it means the upnp server.
It is suggest that you use port forward etc manually instead of let upnp change the ports.
