Usb drive automount on linux
Hi everyone, I have a GL-MT6000 router, I mainly use Linux and I would like the disk inserted into the router to mount automatically when the system starts. I have made several attempts to modify the "fstab" file but without success; on my old router I managed without too many problems.
Could anyone help me?
Thank you!
Does the router use GL firmware?
If yes, the USB Disk Driver will auto mount to /tmp/mountd/ when it plug-in or the OS start.
What can I do if I want to disable this auto mount feature?
Anyone can tell which script(s) is responsible for this auto mount USB drive?
I am also using GL-MT6000.
SSH to router:
vi /etc/init.d/gl_nas_diskmanager
Add # to make the content of the red box is invalidate.
Thank you.
Will try very soon.
