Hi, I want to put a 5v dc usb fan on my mt2500 plastic variant using the usb port. Is it safe to run the usb fan for 24/7? ty
The USB fan may eventually wear out, but power-wise, it should be okay because it would only use 1 or 2 watts of power. You may want to occasionally clean out the dust accumulation.
