Hi there! I was really impressed by the ad and description, so I ended up purchasing a GL.iNet Slate 7 (GL-BE3600) router, hoping to use it with the following modems:
- T99W175
- Sierra EM9190
- Netgear MR1000
When connecting any of the listed modems via USB and pressing the "Cellular" button on the touchscreen, I receive the message: "No Modem device found". The device also doesn't appear in the UI. Therefore, it doesn't work out-of-the-box.
In the command line, we can see:
root@GL-BE3600:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.213 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 1199:90d3 Sierra Wireless, Incorporated Sierra Wireless EM9190
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.213 xhci-hcd xHCI Host Controller
root@GL-BE3600:~# mmcli -L
/org/freedesktop/ModemManager1/Modem/0 [Sierra Wireless, Incorporated] Sierra Wireless EM9190
root@GL-BE3600:~# mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: c946c0229794773129d1b9cac2c05d186d249d6f
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: Sierra Wireless EM9190
| firmware revision: 03.10.07.00_GENERIC
| carrier config: default
| h/w revision: EM9190
| supported: gsm-umts, lte, 5gnr
| current: gsm-umts, lte, 5gnr
| equipment id: 350884580110444
System | device: /sys/devices/platform/soc/8af8800.usb3/8a00000.dwc3/xhci-hcd.0.auto/usb2/2-1
| drivers: cdc_mbim
| plugin: sierra
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin2 (3)
| state: disabled
| power state: on
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 5g; preferred: none
| allowed: 4g, 5g; preferred: 5g
| allowed: 4g, 5g; preferred: 4g
| allowed: 3g, 5g; preferred: 5g
| allowed: 3g, 5g; preferred: 3g
| allowed: 3g, 4g, 5g; preferred: 5g
| allowed: 3g, 4g, 5g; preferred: 4g
| allowed: 3g, 4g, 5g; preferred: 3g
| current: allowed: 3g, 4g, 5g; preferred: 4g
Bands | supported: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
| utran-9, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
| eutran-7, eutran-8, eutran-12, eutran-13, eutran-14, eutran-17,
| eutran-18, eutran-19, eutran-20, eutran-25, eutran-26, eutran-28,
| eutran-29, eutran-30, eutran-32, eutran-34, eutran-38, eutran-39,
| eutran-40, eutran-41, eutran-42, eutran-46, eutran-48, eutran-66,
| eutran-71, utran-19, ngran-1, ngran-2, ngran-3, ngran-5, ngran-28,
| ngran-41, ngran-66, ngran-71, ngran-77, ngran-78, ngran-79
| current: eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
| eutran-8, eutran-12, eutran-13, eutran-14, eutran-17, eutran-18,
| eutran-19, eutran-20, eutran-25, eutran-26, eutran-28, eutran-29,
| eutran-30, eutran-32, eutran-34, eutran-38, eutran-39, eutran-40,
| eutran-41, eutran-42, eutran-46, eutran-48, eutran-66, eutran-71
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 350884580110444
| enabled locks: fixed-dialing
3GPP EPS | initial bearer apn: fast.t-mobile.com
| initial bearer ip type: ipv4v6
3GPP 5GNR | mico mode: unsupported
| drx cycle: unsupported
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
Please help me configure it!
