Is it possible to power cycle the built in USB port from software in the MT300N-V2? I have a device that tends to hang connected to the router through a small USB2.0 hub, and I have tried using the reboot command from the GL-Inet screen and the power on the USB port does not cycle appear to cycle (LED on hub does not go out), I have not yet tried a reboot command from within Luci. In an ideal world I would like to write a script to detect non-response from USB device and then issue a power cycle of the USB port, either that or use a brute force power cycle of the port every 24 hours approach.
thanks Ike
