Happy Labor Day, fellows. Well, I asked and referred this question in the past but never got a satisfactory resolution. Until firmware 3.104, the connected media (USB & SD) have always shown their correct sizes in Windows 10, therefore able to be used with no issue whatsoever. However, starting with firmware 3.105 and now with the latest 3.203, the sizes of these same media are reduced respectively to the same: Free = 89.2 MB; Total = 92.4 MB ! Yes, that’s “MB” while the correct sizes are both: Total = 128 GB (that’s right, GB!) and, under “GL-Samba” folder holding now the shares. Note that GL-Samba folder never showed up in previous firmware 3.104 (at least not automatically) where the shares could be accessed directly in Windows with actual sizes (free and total spaces) identified correctly… So, with this issue now, Windows is unable to perform any task requiring more space on those media due to the annotations of mere 89.2 MB free and 92.4 MB total.
Again, why this problem? And why can’t the media be reached automatically with their real sizes as previously and without being under the GL-Samba" folder?
Doesn’t anyone else see that? Or should one has now to configure a setting from these new firmware to have it reading and showing the true sizes?
Thank you for your deep attention and much appreciated help!
