Hi, can GL-iNet provide the driver (i think i’ll need both serial.ko and pl2303.ko) for my USB serial? I vaguely recall earlier version had it supported, but it doesn’t seem like the case anymore.
You're right, it's built in to kernel. My initial post body has /sys/kernel/debug/usb/devices output showing the device isn't bind to any driver.
After some digging, it looks like my device is a refresh'ed PL2303 adapter, such that its driver is only added after kernel 5.5 with more than just VID:PID table change. so the KVM's kernel predates that. I attempted manually binding the driver; while that creates the device ttyUSB0, it doesn't work.
[root@glkvm:/sys/bus/usb-serial/drivers/pl2303]# echo 067b 23a3 > new_id
[root@glkvm:/sys/bus/usb-serial/drivers/pl2303]# dmesg | tail -30
[167972.962166] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[167972.962187] usb 2-1: Product: USB-Serial Controller
[167972.962206] usb 2-1: Manufacturer: Prolific Technology Inc.
[167972.962225] usb 2-1: SerialNumber: ECASb153609
[168253.080371] pl2303 2-1:1.0: pl2303 converter detected
[168253.081032] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8484]: -32
[168253.083684] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0404]: -32
[168253.085045] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8484]: -32
[168253.087024] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8383]: -32
[168253.089058] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8484]: -32
[168253.091107] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0404]: -32
[168253.093204] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8484]: -32
[168253.095115] pl2303 2-1:1.0: pl2303_vendor_read - failed to read [8383]: -32
[168253.097082] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
[168253.099719] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0001]: -32
[168253.100998] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0002]: -32
[168253.101703] usb 2-1: pl2303 converter now attached to ttyUSB0
[168299.777113] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0008]: -32
[168299.778982] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0009]: -32
[168299.785100] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
[168299.793018] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
[168299.799059] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
[168317.738581] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
[168330.913879] RKMODULE_GET_HDR_CFG
[168330.914003] rkisp rkisp-vir0: can not get first iq setting in stream on
[168330.915151] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:1
[168330.915186] rockchip-mipi-dphy-rx: data_rate_mbps 1000
[168330.916246] rkisp0: MIPI error: packet: 0x01000000
[168330.927355] rkisp0: MIPI error: packet: 0x00000101
[168458.725046] pl2303 2-1:1.0: pl2303_vendor_write - failed to write [0000]: -32
Looks like the i'd have to either use a different adapter, or to build the backported driver. Can you point me to where to find the kernel source and toolchain, so i can build driver for that? Or does GL-iNet has a way to ask if chip vendor (rockchip) already has a backported driver?
Thanks! gpt-6.1-sol built me the back ported driver very quickly from those kernel source and toolchain. Putting the driver here since it might be helpful to others.
[ 179.255076] usb 2-1: new full-speed USB device number 3 using ohci-platform
[ 179.487159] usb 2-1: New USB device found, idVendor=067b, idProduct=23a3, bcdDevice= 3.05
[ 179.487208] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 179.487224] usb 2-1: Product: USB-Serial Controller
[ 179.487238] usb 2-1: Manufacturer: Prolific Technology Inc.
[ 179.487251] usb 2-1: SerialNumber: ECASb153609
[ 179.490344] pl2303_rm1 2-1:1.0: pl2303_rm1 converter detected
[ 179.491383] usb 2-1: pl2303_rm1 converter now attached to ttyUSB0
