USB Tethering with GL-MT300N-V2
Recently purchased a GL-MT300N-V2, have updated to latest firmware.
Connected via USB to a Galaxy S9 running on Android 10 security version 1 April 2020
On the GUI I get the notification for USB0 to connect, click onto it and nothing happens just spins.
I have tried plugging the phone into laptop directly and USB tethering works perfectly, have tried 3 USB cables from cheap to expensive and even the genuine Samsung cable.
Tried my sim in an old Galaxy S8 and that works fine.
Tried Two Galaxy S9 and a Galaxy S10 all on the same firmware version and none of them work.
Any advice please?
I am afraid if this router does not work with galaxy s9 I will need to return it, can anyone from support help please?
Hold on. Seems we found the problem. It should be the same as S10.
We will have a 3.104 firmware for MT300N-V2 solving this issue. Pls hold on a moment.
Thanks, will it be available for auto update or will I need a manual firmware file?
Can you pls try v3.104 from
https://dl.gl-inet.com/firmware/mt300n-v2/testing/
Same problem, just spins and won’t connect
I am an S9+ user. I have tried 3.102 and 3.104 firmware for MT300N-V2 and they both can internet with tethering normally. However, I cannot change the method of USB directly from the control panel. I need to change it from setting.
Maybe this is the bug of Samsung mobile phone.
Hello, I’m having exactly the same problem with a Samsung Galaxy S9+ on Android 10 !
I even went and bought a cheap usb 2.0 cable to try with it and still nothing … the connect button spins for a moment a nothing happens …
Tried with the last firmware and the testing one too. Issue not fixed.
I just tested the USB tethering on a Samsung S21(5G) with android 11. The tethering works fine with Mango(Firmware V3.105)here is the download link: GL.iNet download center
But I must tell you guys, make sure your USB cable is a cable that can transfer data with samsung smartphone because I tried 3 USB cables, only one can work with android smartphone data transfer, so you can select connection method (charge only, USB tethering etc…) in the notification bar.
