Hello everyone,
is it possible to use multiple smartphones as usb tethering at the same time without having to change the smartphones separately in the GUI every time I switch?
Hello everyone,
no, not possible.
One usb the Tethering/bluethoth and one hotspot WiFi
ok thanks for the info. would that be possible if i plug a lan to usb adapter into the wan port and use it to activate usb-c tethering without having to change the smartphone in the interface?
If your mobile phone supports such a magic it might be possible.
