I'm having difficulty tethering a travel router to a Sonim XP3+ (Android 14). On both a Mango 2 and a BerylAX, most recent firmwares, after the router is fully booted, I plug in the phone, and on the phone it registers as tethered, but in the router GUI no device is recognized. I have no issue tethering with a Pixel 3 (Android 11) or a Pixel 10 (Android 16).
Supposing the issue is with the phone, I can tether the Sonim to a windows 11 laptop without issue, and to a Mangov2 using the latest vanilla Openwrt, after setting up the USB01 interface.
I also have no issue connecting to the Sonim as a hotspot.
Thanks for the detailed tests. Could you connect the Sonim XP3+ to the Mango 2, enable USB tethering, and then export the router logs and seng it to us via private message to check?
How to export logs:
How to send private messages:
Reporting back here. This phone runs a version of Android 14 AOSP as a RNDIS device andt has some issues.
On my Mango running OpenWRT 25.12.6 and kmod-usb-net-rndis 6.12.112-r1 (which I had to load, as it is not part of the default firmware), tethering works fine.
On my BerylAX with the beta GL-iNet OP25 firmware, which is also based on OpenWRT 25.12.6 and has the same version of kmod-usb-net-rndis, tethering also works fine, now, after a few false starts. I haven't gone back to the stable firmware to try it
On a Windows 11 PC, it doesn't start, reporting a DHCP issue. Disabling "USB Tethering" on the phone and re-enabling it causes it to start, and thereafter works fine.
On a Mango 2, same as the Windows 11 PC, although enabling wifi and disabling it again, then enabling USB Tethering, also works.
My suspicion is that there is something in the Tethering Module of AOSP 14 that stalls. I'm continuing to pursue that, but at least there is a workaround.
