I have a USB150 Microrouter, working fine in router mode, up-to-date firmware.
I can load my ovpn file into the OpenVPN Client screen, but when I attempt to connect I get a yellow popup with "WARNING: No internet" and then nothing.
I have pasted a redacted version of the ovpn file below. (The unredacted file works fine with the macOS OpenVPN client application.)
Is there something wrong in my setup, or is there somewhere I can look to debug further?
Thanks
client
proto udp
remote my.url.net 993
dev tun
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
verify-x509-name server_abcde name
auth SHA256
auth-nocache
cipher AES-128-GCM
tls-client
tls-version-min 1.2
tls-cipher TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
setenv opt block-outside-dns # Prevent Windows 10 DNS leak
verb 3
<ca>
-----BEGIN CERTIFICATE-----
abcde
-----END CERTIFICATE-----
</ca>
<cert>
abcde-----END CERTIFICATE-----
</cert>
<key>
-----BEGIN PRIVATE KEY-----
abcde
-----END PRIVATE KEY-----
</key>
<tls-crypt>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
abcde
-----END OpenVPN Static key V1-----
</tls-crypt>
