mack
July 13, 2016, 3:51am
I would like to get usbip-server
running on the GL-MT300A
USB over IP tunnel [Old OpenWrt Wiki] (Last Modified 2016/06/17 13:58) suggests running:
opkg install http://downloads.openwrt.org/attitude_adjustment/12.09/ar71xx/generic/packages/usbip_1.1.1-2_ar71xx.ipk
opkg install http://downloads.openwrt.org/attitude_adjustment/12.09/ar71xx/generic/packages/usbip-client_1.1.1-2_ar71xx.ipk
opkg install http://downloads.openwrt.org/attitude_adjustment/12.09/ar71xx/generic/packages/usbip-server_1.1.1-2_ar71xx.ipk
Unfortunately, attempting to install
in this way provokes the following error:
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for usbip found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package usbip.
opkg print-architecture
yields:
arch all 1
arch noarch 1
arch ramips_24kec 10
uname -a
yields:
Linux GL-MT300A 3.18.27 #12 Sat Apr 23 16:00:11 HKT 2016 mips GNU/Linux
Does anyone have any further ideas/suggestions/experience on how to get
usbip-server
running on the
GL-MT300A
Could this be a simple matter of modifying /etc/opkg.conf
Or perhaps there is an alternate source of packages built for the GL-MT300A
's architecture?
Or is the only way round this to cross-compile?
e.g. following the process described here (Last Modified 2016/02/06 13:26)
alzhao
July 14, 2016, 11:58am
2
You are using the wrong architecture.
GL-MT300A is ramips, you are trying to install from ar71xx package.
You can try files here: Index of /attitude_adjustment/12.09/ramips/rt288x/packages/
mack
July 14, 2016, 2:44pm
3
Good catch. Thanks.
I have now successfully manually run opkg install
on usbip
and its dependencies from that package list.
Unfortunately, there seems to be a dependency chain for usbip-server
that cannot be satisfied from that set of packages:
usbip-server_1.1.1-2_ramips.ipk
-> usb-client
-> kmod-usbip-client
kmod-usbip-client_3.3.8-1_ramips.ipk fails to install with the following message:
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-usbip-client:
* kernel (= 3.3.8-1-8968c1c04d7a0de8ee5844d849dd3e08) *
* opkg_install_cmd: Cannot install package kmod-usbip-client.
kmod-usbip
and
kmod-usbip-server
3.18.27-1
are both available on the default package feed, but
kmod-usbip-client
does not seem to exist.
Any ideas on how I can satisfy the kmod-usbip-client
dependency on my box.
Is there some other package list for the 3.18.27-1
kernel?
Is there a simple means by which I can upgrade to the 3.3.8-1-8968c1c04d7a0de8ee5844d849dd3e08
kernel?
alzhao
July 14, 2016, 3:14pm
4
The problem is here, you cannot install kernel modules from other repo. Both kmod-usbip-client and kmod-usbip-server should be there. Seems you are trying to install kmod-usbip-client_3.3.8 from OpenWrt AA, not our repo
Here is the solution:
Don’t change opkg.conf, use our stock firmware only v2.20
do a opkg update and install kmod-usbip-client, kmod-usbip-server, kmod-usbip
manually download usbip, usbip-server and usbip-client to the router’s /tmp foder
opkg install /tmp/usb*.ip
Hope this works
mack
July 15, 2016, 3:12am
5
Success!
root@GL-MT300A:~# usbipd
usbipd: info: starting usbipd (usbip-utils 1.1.1)
usbipd: info: listening on :::3240
Thankyou.
Updating to 2.20 (and downloading rt288x packages from Index of /attitude_adjustment/12.09/ramips/rt288x/packages/ ) was the answer.
progit
October 2, 2016, 2:51pm
6
I have exactly the same problem as that of mack . I have exactly the same router GL-MT300A, I would like to get package usbip-server .
I tried to do as written above.
I install packages kmod-usbip-client, kmod-usbip-server, kmod-usbip from your repository.
Then I downloaded manualy usbip, usbip-server and usbip-client to the router’s /tmp foder from https://downloads.openwrt.org/attitude_adjustment/12.09/ramips/rt288x/packages/ . I try to install, but nothing comes out.
root@GL-MT300A:/tmp# opkg install usbip*
Unknown package 'usbip-client'.
Unknown package 'usbip-server'.
Unknown package 'usbip'.
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for usbip-client found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package usbip-client.
* pkg_hash_fetch_best_installation_candidate: Packages for usbip-server found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package usbip-server.
Tried to use the flag "
--force-depends ", the situation is similar. I tried install it on
different versions of firmware: 2.19, 2.20, 2.22, clean . Nothing changes.
I also tried install firmware from trunk:
https://downloads.openwrt.org/snapshots/trunk/ramips/mt7620/openwrt-ramips-mt7620-gl-mt300a-squashfs-sysupgrade.bin .
But it is very bad work, the router periodically hangs.
opkg print-architecture yields:
arch all 1
arch noarch 1
uname -a yields:
Linux GL-MT300A 3.18.27 #7 Wed Jul 6 10:47:10 HKT 2016 mips GNU/Linux
Does anyone have any further idease on how to get usbip-server running on the GL-MT300A ? This package it is very necessary.
alzhao
October 3, 2016, 3:14pm
7
@progit , please use the following, don’t omit .ipk. If you omit it, it search the database, not the files.
opkg install usbip*.ipk
mack
December 30, 2016, 10:03pm
8
Half a year later and I’ve reset my device after updating to the latest firmware:
Unfortunately, this puts me back at square one - the steps that previously led to success (downloading from attitude_adjustment/12.09/ramips/rt288x/packages/ ) no longer works.
I am now experiencing the exact same error as progit.
I’m guessing that this is going to come down to cross-compiling the userland tools.
Can anyone report any success with getting usbip to work on GL-MT300A (ramips_24kec, Linux GL-MT300A 3.18.27)?
