Use GL-AX1800 as ethernet WIFI adapter only
I’ve a WIFI Network at my home “WIFI 6” , I want to connect a device that have only wired connexion .
The goal is to use a device like GL-AX1800 or GL-MT3000 as an adaptor only
This mean . connect the GL on existing WIFI network , connect my wired device on the GL’s RJ45 port
but disable WIFI Repeater
I don’t really find a solution ( looking on documentation) do disable WIFI repeater
Is somebody confirm it’s possible ?
Thank you for your help
You can use Extender or WDS.
In the router web admin panel->network->network mode
Thank you for your reply. I will try this option as soon as I receive device
Extender mode and then turn off broadcast of its own SSID.
Does Extender network mode allow WWAN wifi connection over 5GHz?
