Sorry to reply late.
Pls try upgrading the op24 firmware, and the rate of the repeater interface can be found in Luci> Network> Wireless, the ifname of 5G 5epeater is sta1.
Hello I have already posted the rate of the repeater interface. check previously posted pics
I assume the second line is the negotiate speed of repeater interface, and the TX is 390 Mbps.
The speedtest result is about 395 Mbps.
They are corresponding. But the reason why the negotiation rate is not high, probably related to the wireless connection between the room environment, the distance of primary router and Flint 2.
The 5GHz WiFi of Flint 2 up to 4800Mbps, you can try to move the Flint 2 close to the primary router, so that the negotiation speed may be better.
Ok so if i am using PPOE passthrough then my problems will be solved?
PPPoE? Is it a wired connection from the Flint 2 to ISP modem?
If yes, the wired connection will get the better speed.
yes wired.. i will look into that and get back to you.
thanks
