Howdy y’all,
(Using a Flint GL-AX1800)
Is there any particular reason why GL.iNet devices use the lan “connection-specific DNS suffix” instead of the more common local, or is my head on backwards? It seems that more servers and services prefer local to lan. One instance is this caused issues with my TrueNAS core server via SMB, since (by default), it’s set to assign itself the suffix of local.
Is there any strong reason it should stay this way, or other reasons why the default should be changed-over? More curious than anything.
Edit: To clarify, I’m well-aware it can be changed in the LuCI GUI, however I am referring to the out-of-box defaults.
Cheers,
Matt
