Use VPN for a subnet and don't for www
i have two mt3000, one acting as wiregard server and the other one as wiregard client.
On client side i have configured the VPN Policy Based on the Client Device, so with my pc i can use the vpn, and the other devices are free to navigate on internet without vpn.
This is the problem: on my pc i want to use the vpn just to reach the 192.168.0.0/16, and navigate all the other website without vpn. Is there a way to do this config? Thanks!!
Just adjust the VPN policy to your needs: VPN Dashboard - GL.iNet Router Docs 4
You could exclude your PC or exclude the whole network by using Based on the target domain or IP
Hi! I followed you suggestion, and i switched to target domain, as you can see in the picture below. Now it's working!! However now every single device can access the vpn, and not only my pc. Maybe i have to setup the single rule option, but i dont know where i am supposed to write that rule. (maybe on server side?)
Unfortunately, the rules are mutual exclusive.
You could try to use the firewall to exclude all devices but your PC.
