Use X750v2 as main home router
Can I yse X750v2 as my main router at home? I want to use cellular connection to make my LAN and be able to use cable LAN to connect Mango to create physically separated guest network
Every GL router is capable of being the "home router" - but you should think about your environment and what you want to achieve.
You can connect your Mango via LAN and create another network, but then you might get double NAT.
